Re: Fear of heat- not an issue
Wiley Horne
Hi Bill,
There can be no doubt that the solution you put forward is the low-cost solution. This is a very significant benefit for many. I would encourage anyone considering investing in a grinder to read your comprehensive ‘how to, and why’ in Articles at this site. A competent 3600rpm grinder and wheel can be had for a fraction of the cost of the options we have been discussing in this and related threads. It does require touch and know how to avoid blade-burning, which is why reading your article is a must.
Question: Finding the right wheel will be a head-scratcher for many. Can you be specific, or provide an actual link, to where one can find a 6”, 7”, or 8” wheel, or crowned wheel, of the proper softness? I did a quick check of MSC, and the softest wheel I could find was K—it may be I didn’t look hard enough.
I also went to Travers Tool, and could only find wire wheels. Again, the fault lies with me I’m sure. However, I suspect others would have the same problems searching for an H or I wheel. Or crowned wheel of a stated softness.
Wiley
Messages In This Thread
Tormek: getting old wheel off?
Re: Tormek: getting old wheel off?
Re: Fear of heat
Re: Fear of heat
Fear of heat- any evidence?
Re: Fear of heat- any evidence?
My set up is like yours...
some heat calculations
More exercises with no exact answers
Re: More exercises with no exact answers
Re: some heat calculations
It sure as hell ain't from heat
same, but details different, and a question
Re: same, but details different, and a question
Question
Search surface grinder wheels, Type 1 *NM*
Wheel recommendation
Re: Wheel recommendation
Did it. Here are 2 extensive sources:
Re: Did it. Here are 2 extensive sources:
You have identified the problem
Problem 2
David, please link us to
Re: David, please link us to
I did find this I wheel
What this wheel is, technical data, flawed
Re: Fear of heat- not an issue *LINK*
All these problems aren't
already equipped vs. not
Please listen, more issues that aren't......
Re: Please listen, more issues that aren't......
Re: Tormek: getting old wheel of littl
Similar to pulling rusted car wheels
Re: Similar to pulling rusted car wheels
