Re: Similar to pulling rusted car wheelsResponse To:
Similar to pulling rusted car wheels () Wiley Horne
Hi Jim,
I’ll try the low-tech plan first, using a couple of plywood slabs or more likely thin steel bars to suspend the whole apparatus by the stuck wheel`, then try to break the seal by punching on the arbor end.
If that doesn’t work, will look into the can puller, although this is a 10-inch wheel so .......
Thanks very much for a good plan.
Wiley
Messages In This Thread
- Tormek: getting old wheel off?
- Re: Tormek: getting old wheel off?
- Fear of heat- not an issue
- Re: Fear of heat
- Re: Fear of heat- not an issue
- Search surface grinder wheels, Type 1 *NM*
- You have identified the problem
- I did find this I wheel
- Re: Fear of heat- not an issue *LINK*
- Re: Fear of heat
- Similar to pulling rusted car wheels
- Re: Similar to pulling rusted car wheels
