Similar to pulling rusted car wheels
Jim Matthews
If you can get a large "punch" or clevis pin from your hardware store, judicious tapping with a beefy hammer should move things along.
Don't fix the motor to anything immobile or clamp it down.
I would turn the works sideways, suspended by the stuck wheel.
A sheet of 5/8" plywood, cut in half with a notch to fit around the shaft should do.
Put something soft under the works for when it drops free.
If you're more inclined to gentle persuasion, consider O'Reilly's autoparts yo rent a "can puller".
https://images.app.goo.gl/8yQxBtyH6AsFFEgu5
Messages In This Thread
Tormek: getting old wheel off?
Re: Tormek: getting old wheel off?
Fear of heat- not an issue
Re: Fear of heat
Re: Fear of heat
Fear of heat- any evidence?
Re: Fear of heat- any evidence?
My set up is like yours...
some heat calculations
More exercises with no exact answers
Re: More exercises with no exact answers
Re: some heat calculations
It sure as hell ain't from heat
Re: Fear of heat- not an issue
same, but details different, and a question
Re: same, but details different, and a question
Question
Search surface grinder wheels, Type 1 *NM*
Wheel recommendation
Re: Wheel recommendation
Did it. Here are 2 extensive sources:
Re: Did it. Here are 2 extensive sources:
You have identified the problem
Problem 2
David, please link us to
Re: David, please link us to
I did find this I wheel
What this wheel is, technical data, flawed
Re: Fear of heat- not an issue *LINK*
All these problems aren't
already equipped vs. not
Please listen, more issues that aren't......
Re: Please listen, more issues that aren't......
Re: Tormek: getting old wheel of littl
Re: Similar to pulling rusted car wheels
