Mostly Nicholson and bahco *PIC*
David Weaver
A couple of these are o1 and some are files. I mention getting bigger triangular files because their triangular shape makes them easier to hammer flatter.
By defletion, I mean the very edge of the steel gets bent, probably because o1 is a little less tough than plain carbon steel and it shows up when stropping a very low bevel angle.
The files used for these are smaller. I used x heavy taper files to cut the teeth into my frame saw. Those would've made good starting stock for chisels, but I threw them away when they were dull. The small knives made of triangular files here are about a sixteenth thick at the spine.
They could be made more neatly and filed to a nicer shape with crisp lines, but they're just to sharpen on the buffer, so they're sloppy as can be.
