Sure isn't...Response To:
Re: not hand tool friendly!! () John in NM
I doubt those were ever made by hand. I've drilled holes like that before, so you could do it with a brace if you used a really big chunk of wood and then cut the barrel channel to match.
In a factory, a lot of those long cuts are made with something similar to a horizontal mill - that is how I would do the barrel channel on that piece for example, gang together about 6 cutters with spacers on a long arbor and do 6x at once. But that round hole has to be done with something like a router or perhaps they did drill it. I'll look closely at one when I get back to the shop (likely a couple weeks) and see what I can tell from tool marks.
Messages In This Thread
- A break from the steel discussions... *PIC*
- Stock finished and installed *PIC*
- Re: Stock finished and installed
- Re: A break from the steel discussions...
- Very nice job. *NM*
- Scrumptious block of walnut!
- Fascinating, John
- Yes....
- Nice!
