Re: Heatless burrs for dremel?
david weaver
In larry's video, IIRC, he uses the (conical) shaped stones on a foredom to grind hollow planes.
I don't remember if they were pink surface grinding type abrasive or if they were something else.
I have used the cheap versions of those from harbor freight and other places without issue in a drill press (freehand) at relatively low speed.
It's one of those things where you do it when you have to and that's it as even with that type of fixture, the stone can run away from you and round over the corner of an iron.
