Re: Stearate coating
Re: Stearate coating ()
david weaver
Even india stones are probably hard on a diamond hone. SiC, definitely. I think very coarse stones for anything other than bevel work are generally a pipe dream (at least considering them to be "good" for that kind of work).
Kanaban with diamonds is good (and very cheap), but even the kanaban will need to be flattened after a while, which is a pain in the rear. PSA paper on glass is much faster for nearly all things, but not quite as cheap in the long run (the time tradeoff is worth it, though).
The only really good coarse stone is the crystolon type or an equivalent type for water, and they don't like to stay flat - and flattening them tends to grade them and load them.
I have bought a lot of coarse stones, but wouldn't again buy anything other than a medium crystolon below the shapton 1000 grit level.
I guess an india stone is technically more coarse than that, but they are only slightly faster than a stone of that type once they've settled in, and you can keep them flat by using them properly. There is no absolute need that I can think of for a flat stone in the shop. A skilled user can maintain the back of an iron or chisel on the end of a swayed stone, even though it may not be ideal.
Messages In This Thread
flattening Waterstones- shapton pro
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
What a great thread this has been.....
Re: What a great thread this has been.....
well then....
Traditional Method
Re: Traditional Method
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
Re: Traditional Method *LINK* *PIC*
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
which side to use?
Re: which side to use?
Quick and dirty summary:
Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Plastic laminating sheet
Re: Atoma - $64
Re: Quick and dirty summary:
Re: flattening Waterstones- shapton pro
A different perspective *LINK*
Re: A different perspective
My thoughts
CBN and grit
How Are You Cleaning The CBN Wheel . . .
Re: How Are You Cleaning The CBN Wheel . . .
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
The flat wheel surface - or not..
Re: The flat wheel surface - or not..
Re: My thoughts
Re: My thoughts
My Opinion...
Re: My Opinion...
Not universal preference
to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
Re: to date
lapping film?
Re: lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Yes, this
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Flattening
Diamond plates
Re: Diamond plates
Revise atoma price...
Re: Revise dia-sharp price...
