Why grind unhardened steel on CBN?Response To:
Re: How Are You Cleaning The CBN Wheel . . . () Patrick Chase
The principal benefit of CBN is that it efficiently grinds hardened metals, without releasing excessive heat that might detemper them.
If you're grinding normalized/annealed O1 then it's a "don't care" on both counts: You can get the part red-hot without damaging it (anything below 1300F is OK), and it will grind easily on conventional abrasives like AlOx.
I use a conventional wheel or belt grinder for that. While CBN load-up is easily fixed (as you say, just grind something hard) *any* grinding puts at least a little wear on the wheel, and there's no reason to do that for soft steel.
Messages In This Thread
- flattening Waterstones- shapton pro
- Another possibility presents itself......
- What a great thread this has been.....
- Re: What a great thread this has been.....
- a little bit the Indian and a little bit arrow
- which side to use?
- Quick and dirty summary:
- Atoma - $64
- Re: Quick and dirty summary:
- Re: flattening Waterstones- shapton pro
- A different perspective *LINK*
- Re: A different perspective
- My thoughts
- CBN and grit
- The flat wheel surface - or not..
- Re: My thoughts
- Re: My thoughts
- My Opinion...
- My thoughts
- lapping film?
- Diamond plates......
- Flattening
