Re: How Are You Cleaning The CBN Wheel . . .
Patrick Chase
Are you using laminated (Japanese) plane irons and chisels?
Homogeneous Western tools that are hardened all the way through are typically Rc59 and above, and that's enough not to clog a CBN wheel. I don't worry about it or clean the wheel at all.
Mild steels and iron can indeed load the wheel. That's only happened to me once that I remember, when I used my CBN wheel to shape some mild 1018. I ground a hardened scraper (~Rc52) a bit to remove it and the wheel didn't seem any worse for wear, though I've avoided unhardened metals since.
I don't hollow-grind laminated tools in any case. They don't really need it because they sharpen so easily to begin with, and I'm concerned that hollow-grinding slightly compromises the integrity of the weld. I don't know if it's enough to matter, but I don't take chances.
Messages In This Thread
flattening Waterstones- shapton pro
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
What a great thread this has been.....
Re: What a great thread this has been.....
well then....
Traditional Method
Re: Traditional Method
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
Re: Traditional Method *LINK* *PIC*
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
which side to use?
Re: which side to use?
Quick and dirty summary:
Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Re: Stearate coating
Plastic laminating sheet
Re: Atoma - $64
Re: Quick and dirty summary:
Re: flattening Waterstones- shapton pro
A different perspective *LINK*
Re: A different perspective
My thoughts
CBN and grit
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
The flat wheel surface - or not..
Re: The flat wheel surface - or not..
Re: My thoughts
Re: My thoughts
My Opinion...
Re: My Opinion...
Not universal preference
to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
Re: to date
lapping film?
Re: lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Yes, this
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Flattening
Diamond plates
Re: Diamond plates
Revise atoma price...
Re: Revise dia-sharp price...
