Patrick Chase
I should be clear that I use diamond plates (mostly Atoma) for the vast majority of stone-flattening chores. As you say they get the job done quickly and at least as cleanly as any other option.
Unfortunately I own some stones that can't be allowed to interact with a diamond plate. For example, I stripped almost all of the diamonds off of a 10" x 4" DiaFlat (a $200 plate...) by using it to true up a Sigma Select II #240. I expect that I'd see similar results with coarse SiC-based stones like a Crystolon or my Sigma #120.
I use a well-worm Atoma #140 plate to flatten stones down to #320 or so, but below that I switch to loose SiC grit. It's almost as fast as a diamond plate once you have the hang of it (and figure out some tricks like using sacrificial plastic laminating sheets to "hold" the grit), though it makes a god-awful mess.
Messages In This Thread
- flattening Waterstones- shapton pro
- Another possibility presents itself......
- What a great thread this has been.....
- Re: What a great thread this has been.....
- a little bit the Indian and a little bit arrow
- which side to use?
- Quick and dirty summary:
- Atoma - $64
- Re: Quick and dirty summary:
- Re: flattening Waterstones- shapton pro
- A different perspective *LINK*
- Re: A different perspective
- My thoughts
- CBN and grit
- The flat wheel surface - or not..
- Re: My thoughts
- Re: My thoughts
- My Opinion...
- My thoughts
- lapping film?
- Diamond plates......
- Flattening
