Re: to date
Re: to date ()
TomD
There is a rule in shooting that you should determine when you are working on form, gear, whatever, and when you are actually shooting for score. There is a lack of discipline that comes from switching back and forth in a day at the range, without any real accountability to results. Maybe a better example would be the golf course and the driving range. One is for swing practice, the other is not normally where you go to practice your swing. I'm a big believer that in woodworking you make the most rapid progress when you do some actual practice, and try to do projects in a different frame of mind.
In woodworking we would benefit from knowing or considering when something is just for the pursuit of knowledge, and when it has some output purpose. But it is far too complex an activity to really set out the parameters. Guys like Derek are great examples because he has a huge inquisitiveness, but also a considerable output. Somehow he has it all together.
I only get annoyed when the research leads to an attitude that one must have whatever the latest or greatest is, which is almost always nonsense.
Messages In This Thread
flattening Waterstones- shapton pro
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
What a great thread this has been.....
Re: What a great thread this has been.....
well then....
Traditional Method
Re: Traditional Method
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
Re: Traditional Method *LINK* *PIC*
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
which side to use?
Re: which side to use?
Quick and dirty summary:
Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Re: Stearate coating
Plastic laminating sheet
Re: Atoma - $64
Re: Quick and dirty summary:
Re: flattening Waterstones- shapton pro
A different perspective *LINK*
Re: A different perspective
My thoughts
CBN and grit
How Are You Cleaning The CBN Wheel . . .
Re: How Are You Cleaning The CBN Wheel . . .
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
The flat wheel surface - or not..
Re: The flat wheel surface - or not..
Re: My thoughts
Re: My thoughts
My Opinion...
Re: My Opinion...
Not universal preference
to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
Re: to date
lapping film?
Re: lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Yes, this
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Flattening
Diamond plates
Re: Diamond plates
Revise atoma price...
Re: Revise dia-sharp price...
