Stearate coatingResponse To:
Re: Sandpaper Flattening & Shaptons () Patrick Chase
Was the sandpaper you used stearated ("no-load" coating)?
What you describe sounds like what I would expect if the stearate coating transferred to the stone. If you use cheap, uncoated paper that isn't an issue.
I prefer loose SiC grains for stone flattening FWIW, but there's nothing magical about sandpaper, either good or bad. It works as well as anything else provided you understand what you're using and select the right type.
Messages In This Thread
- flattening Waterstones- shapton pro
- Another possibility presents itself......
- What a great thread this has been.....
- Re: What a great thread this has been.....
- a little bit the Indian and a little bit arrow
- which side to use?
- Quick and dirty summary:
- Atoma - $64
- Re: Quick and dirty summary:
- Re: flattening Waterstones- shapton pro
- A different perspective *LINK*
- Re: A different perspective
- My thoughts
- CBN and grit
- The flat wheel surface - or not..
- Re: My thoughts
- Re: My thoughts
- My Opinion...
- My thoughts
- lapping film?
- Diamond plates......
- Flattening
