A different perspective *LINK*
i know discussing sharpening techniques and equipment is like discussing religion but anyways,
i'd like to keep it on topic if i can. i decided i wanted to change my sharpening routine for chisels and plane blades. i learned a lot but now i decided to get some shapton "pro" Kuromako stones.
so i'd like to know what people here flatten them with and how often? is it a routine or just when you feel it needs it? do you measure it? eye ball it?
i have yet to purchase any flattening stone so i'm open to suggestions.
thank you!
Hi Joseph
The Pro Shaptons are good stones, but I only like the 1000 grit. I prefer the Sigma 6000 and 13000 to fill out the range. These are flattened with a Shapton diamond stone, which I have had for 10 years. Before then I used a DMT Extra Coarse (in the duo format).
There are other alternatives, stones that do not need flattening - none, zip ... well, maybe once a year. The stones I use most of the time are two ceramic Spyderco (2"x8" Medium and Ultra Fine).The Spydercos are hard and retain their flatness like oilstones, but are worked dry. Spyderco do not say what the grits are, but they are reputed to be 1500-2000 and 6000-8000, respectively (it would not surprise me if the Ultra Fine is about 10000 as it leaves a mirror finish).
Even more important than honing is the decision to use a secondary bevel or create a microbevel on a hollow grind. I hollow grind as I can freehand on this, and find it the fastest and most efficient way to create and maintain a sharp edge. Consequently, my emphasis is first placed on creating the hollow grind, and to this end I highly recommend CBN wheels on a dry grinder. This can safely grind a blade to the edge (as can a Tormek). Once this is possible, the flatness of a stone becomes much less important, as does using the "best" stone around (however, the stones mentioned above are excellent).
If you prefer a secondary bevel using a honing guide, then stone flatness is an issue, and I would recommend the Pro Shapton/Sigma system above along with a good diamond stone (not the Shapton I use as it is expensive and unnecessary - I picked one up at a sale).
Messages In This Thread
flattening Waterstones- shapton pro
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
What a great thread this has been.....
Re: What a great thread this has been.....
well then....
Traditional Method
Re: Traditional Method
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
Re: Traditional Method *LINK* *PIC*
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
which side to use?
Re: which side to use?
Quick and dirty summary:
Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Re: Stearate coating
Plastic laminating sheet
Re: Atoma - $64
Re: Quick and dirty summary:
Re: flattening Waterstones- shapton pro
Re: A different perspective
My thoughts
CBN and grit
How Are You Cleaning The CBN Wheel . . .
Re: How Are You Cleaning The CBN Wheel . . .
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
The flat wheel surface - or not..
Re: The flat wheel surface - or not..
Re: My thoughts
Re: My thoughts
My Opinion...
Re: My Opinion...
Not universal preference
to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
Re: to date
lapping film?
Re: lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Yes, this
Diamond plates......
Re: diasharp vs. diaflat
Re: I think...
Re: I think...
Flattening
Diamond plates
Re: Diamond plates
Revise atoma price...
Re: Revise dia-sharp price...
