Re: diasharp vs. diaflat
Diamond plates...... ()
david weaver
apologies, I got both of those confused.
I have used the bench stones, dia flat, dia sharp and the duosharp. From time to time, the diasharps have flatness issues, but the duosharps, dia flat and bench stones do not (the duos and bench stones are plastic, I guess it's easier to get flat stock moulding it).
The plastic "bench stones" are expensive for what they are, but I found the duosharps fine to use.
I have yet to find a diamond hone made in china that's flat from hone to hone. That includes the $50 plates that come from bestsharpening stones (4 thousandths hollow for both that I have, which doesn't sound like a big deal, but you will find that it can create a problem if you prepare a cap iron and iron on it), as well as the gaggle of stones that are about $20 for a two-sided stone.
I understand the iwood japanese hone can also be a bit out of flat (according to stu's stuff), and the extremely expensive apparently chinese-made trend plate that some of the retailers sell has a poor flatness record on the shaving forum. trend's flatness quote is per inch, so it's relatively meaningless for the plate.
I didn't have the ability to measure the diasharp's flatness the last I used one. If you can't get a 1 1/2 thou feeler through something, it's fine. If you can get a sheet of paper through the center of a diamond hone, it may present problems.
Apologies for confusing the diasharp and diaflat. Based on what I've seen of the lower cost DMTs, though, I'd stick with the plastic ones if flatness counts, but I'd still defer back to atoma because one atoma will last as long as about 10 duosharps. I blew out my first duosharp in about a year. Each chinese equivalent ("DMD" brand, etc), about the same. I have two atomas that have been used very heavily and both are still fine and not missing any significant patches.
Messages In This Thread
flattening Waterstones- shapton pro
Another possibility presents itself......
CBN plates
Re: Not making sense..
Diamond wear
Re: Diamond wear
Re: Diamond wear
Re: Diamond wear
What a great thread this has been.....
Re: What a great thread this has been.....
well then....
Traditional Method
Re: Traditional Method
My apologies for being a bit too harsh..
Re: Washita vs soft Arkansas stones...
Re: Traditional Method *LINK* *PIC*
a little bit the Indian and a little bit arrow
Re: a little bit the Indian and a little bit arrow
which side to use?
Re: which side to use?
Quick and dirty summary:
Atoma - $64
Sandpaper Flattening & Shaptons
Re: Sandpaper Flattening & Shaptons
Stearate coating
Re: Stearate coating
Plastic laminating sheet
Re: Atoma - $64
Re: Quick and dirty summary:
Re: flattening Waterstones- shapton pro
A different perspective *LINK*
Re: A different perspective
My thoughts
CBN and grit
How Are You Cleaning The CBN Wheel . . .
Re: How Are You Cleaning The CBN Wheel . . .
Why grind unhardened steel on CBN?
Re: Why grind unhardened steel on CBN?
The flat wheel surface - or not..
Re: The flat wheel surface - or not..
Re: My thoughts
Re: My thoughts
My Opinion...
Re: My Opinion...
Not universal preference
to date
Re: to date
Re: to date
Re: to date
:) *NM*
Re: to date
Re: to date
lapping film?
Re: lapping film?
Re: lapping film?
Re: lapping film?
you are not kidding!
Yes, this
Re: I think...
Re: I think...
Flattening
Diamond plates
Re: Diamond plates
Revise atoma price...
Re: Revise dia-sharp price...
