Sgian Dubh
"But there is one thing you mentioned that's awfully difficult to overcome, and that is planing over a large wide surface (because smoothing a table top wouldn't actually involve many sharpening cycles - my ash bench top required 1...one...uno (with a horrid stanley 70s iron)...anyway, the real issue here is that planing a large wide and long surface can be quite painful."
In my experience David, workbench tops are pretty small. The main flat work area of mine, for example, is only about 1,700 mm long by about 460 mm wide. True, overall the bench is bigger than that, but there's a tool well and a back board set at the same height as the top face of the main flat surface. The only other type of workbench I've used on a regular basis is the traditional English pattern where a wide tool well is enclosed by two work surfaces at either side that are typically about 220-250 mm wide by 1500 mm to 2000 mm long, so there's not much to flatten. In the end of course, it's just a workbench which gets bashed up, so it doesn't need to be pretty, just flat. I'm not particularly exercised by things like tearout on the working surfaces of a workbench top, so I'd never try to set up a plane to achieve a tear free surface - it's not worth the effort.
On the other hand, table tops like one I'm making now are a different story, this one being American white oak 2,500 mm long by 1100 mm wide with clamped ends. This does need to be prepped free of tearout, and your point about working such large surfaces is well made - they're a pain to prep to perfection with just hand planes. They're seldom perfectly flat meaning there are usually slight undulations that even a short number 4 plane won't reach the bottom of (the undulations that is) without significant time and effort so, for me anyway, I don't even try. I just knock off the worst of any steps at glue lines with a plane, and then get at it with scrapers and (usually) power sanding, plus perhaps a bit of hand sanding to finish off. It gets the job done quickly (noisily and dustily too usually which is a bit of a necessary pain) and more than good enough for ~98% of all those that will eventually view the finished article.
The roughly 2% of the population that might be able to work out the surface wasn't prepped entirely with hand planes aren't the sort of people likely to pay me to do such a job, so their informed knowledge of the likely techniques employed doesn't really matter. Unless, of course, they really are paying me to prep such a surface to perfection entirely with hand planes, in which case they'd also presumably expect to pay a matching premium price. Something along those lines has never occurred for me in all my working life in the craft furniture field ... but I guess there's still time yet for that, ha ha. Slainte.
Messages In This Thread
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
