Brian Holcombe
I find it significantly faster than sanding and scraping but anymore I am exceptionally particular around the wood I buy. I spend a lot of time in the lumberyard when I am buying material, I comb over every board examining the grain.
I can plane an ugly surface into something good but why do so when I can avoid 95% of that mess by combing over my purchase.
Messages In This Thread
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
