Re: Pictures
Pictures *PIC* ()
david weaver
I think I might have the left and right mixed up.
The center is most burnished, and not sure if that's due to shaving flow or initial prep.
The bright white line in the middle is the front of the cap iron. Above that is the back of the plane iron, and below that is the rounded (and polished) middle of the cap iron hump.
The projection of the iron shown is about 5 thousandths or 6 thousandths, so the total amount of cap iron shown in the picture is not much - just the leading edge.
No clue if the white line is wear or just the torn off bits left from the initial conditioning. It's a fraction of a thousandth.
Also not sure if the trash left on the picture labeled right (which is probably left) is partly wood dirt, or if it's a couple of thousandths of harshly honed area that was done either with the india stone or washita and not fully polished (could be). You can't actually see any of that with the naked eye and none of it has ever affected use.
This is my favorite plane, and my favorite smoothing iron, so I expect that it'll continue to get used a lot, and i don't expect to do anything to the front of the cap.
This sort of reminds me of the threads on the shaving boards where someone insists that you need to rehone a razor every two weeks to remove accumulated damage. That process is a little different, but with the right (non-abrasive) care, a razor doesn't need to be honed more than every 300 shaves or so (and isn't improved by it, perhaps the opposite is the case).
Messages In This Thread
Cap iron setback and shaving thickness
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
