Pictures *PIC*
Re: Worn Through ()
david weaver
From my 1970s stanley 4 - my favorite, but also the only stanley I've ever had where the iron was a bit soft even for my taste.
Center of the cap iron (the iron is of my own make - as in, just cut 3/32nd O1, file to fit, weed torch, quench and temper).
Neither sharpened nor reset, just pulled from my smoother. I did check this under the big scope - it's probably 5-6 thousandths. I can get a picture of the back of the iron with the big scope, but it won't focus well on the cap unless I put it up on something and do some strange setup - not worth it. So these are the cheap scope pictures (I think everyone with a computer should have one of these, they're $11 and they'll tell you everything you ever need to know except for the finest quality straight razor sharpening).
The left:
The right:
I don't remember what I was doing with this or why the camber is so gradual. It would normally have a couple of thousandths, but it's almost straight.
I also don't remember how I fitted the cap iron because I've been using it for a while. Probably washita and then removal of the very tough washita burr with dursol on leather. Nothing since.
I don't really understand the "cap iron gets dull" thing. Following Steve's post, it's not supposed to cut anything, it's supposed to redirect. It should be a little dull.
There's very little here to suggest degredation. The bright line at the edge may just be mostly burnishing from working the burr, off. I don't know. The fit is tight all the way along.
The tiny brown splotches might be pitch. I looked more closely at them, and they're not rust.
Messages In This Thread
Cap iron setback and shaving thickness
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
