Re: Worn Through ()
steve voigt
Some thoughts on maintaining the cap iron (not directed to anyone in particular):
I use my main three bench planes daily, and has probably been a couple years since I did anything to the cap irons. Once they've been prepared properly, they should stay that way for a long time.
However, it depends on the type of cap iron, and on how they're prepared. Early on, I would prep my cap irons so that they were truly sharp, and the fragile edge would need occasional maintenance. Later, I found that a very slight dulling of the edge, just as part of the process of removing the burr, made maintenance unnecessary. It's important not to overdo this--you don't want a really blunt edge. I do this dulling by stropping (on leather) the crap out of the cap iron edge, in exactly the way that you're not supposed to strop a cutting tool--using lots of pressure and overshooting the angle on both sides.
It's interesting that Holzapffel (1850-ish) and Denning (1880-ish) refer to the cap iron as "moderately sharp" or "the dull iron." I think the above is what they were getting at.
This depends on the type of cap iron, though. A vintage woodie cap iron puts a lot of pressure on the tip, and I think an OEM Stanley does too. So there's no need for tricks like raising a burr with a burnisher. But a so-called "improved" modern cap iron hardly puts any pressure on the tip, so I can see why the burr would be necessary. But that traps you in an unending maintenance cycle. Some improvement.
Regarding resin: When I plane hardwoods, and I plane them almost every day, I don't get any resin build-up. The tip of the cap iron gets tarnished and discolored, but I don't care. When I am planing SYP for any length of time, the resin does build up, but a rag and some mineral spirits or acetone removes the resin easily; there is no need for honing.
Messages In This Thread
Cap iron setback and shaving thickness
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
