Re: Correction
Re: Correction *LINK* ()
TM Stock
Perhaps you might read the thread, Warren - the gist was that the BU/BD nonsense was a religious war at the time and that we were having too much fun lampooning the combatants. It was a nice reminder that some things never, ever change.
Also - why link to a post that includes not a scintilla of content of mine? Why not actually link to one of my posts? Hmm...
So just in case you missed them (could happen...), here ya go:
Post Title: I BELIEVE...I'll Have a Scotch: The other thing I believe is that there are very few of us that do half as well as Frank Klausz does with a beater #4 with a stock blade. I also suspect that Frank would find all this religious nonsense concerning LABU, HABD or FWBW ( the new clothing line...For Woodworkers By Woodworkers) pretty darned silly."
It gets sillier..IIRC, I was doing flight testing at the time on one of my inventions, and the contrast between craft and science was pretty stark...hence, the comments later in the thread.
So why no tear-stained defense of chip breakers? Pretty simple...just a bad case of hand-tool privilege.
Setting the chipbreaker close for close work and back for coarse work (the sort of cross-grain stuff that every glued up panel needs) was something that I took for granted - sort of at the same level as 'might want to install the lever cap prior to using the plane' - in other words, so excessively simple that no one that had already worked with planes for 25 years would consider it remarkable. Certainly something that every student coming out of 7th grade wood shop in the Clarence Central School system had heard a few hundred times courtesy of a competent instructor.
Beyond that - small pond...big frogs.
Messages In This Thread
Cap iron setback and shaving thickness
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
