Re: The most likely
Re: Correction *LINK* ()
david weaver
...repeating myself, but Steve and I had this conversation at least once (and so did Chris Griggs and I, Chris was my guinea pig for explanations before writing anything about the cap iron).
The thing that drove me to the cap iron (seeing these very old conversations about "this new thing is superior" is humorous - and so are some of the old dynamics - some frustrated users from those threads are gone) is likelihood. My day job involves a lot of it.
There are things that are unlikely:
* that someone who knows how to use a double iron well will talk about much else for anything other than curved surfaces
* that double iron planes showed up for a higher cost and people with little income purchased them for any reason other than economic gain
* that someone who claims to have known all about the double iron really did, but never said anything until after the fact
I could probably make a list of ten points.
I don't doubt that a lot of people heard of it being a method of controlling tearout (but most people seem to forget that they did until someone else reminds them), but I doubt many people were using it capably (because doing so pretty much wipes out other things. For example, charlie often talks about scraping and sanding being easier and customers don't care. I scrape flat surfaces from time to time, but I always end up with more marking from a scraper with a sheer finish than I do with a plane).
I have my doubts about the OP here, either. A gutter plane with a cap iron isn't going to be the same as a smoother used for closer work.
Messages In This Thread
Cap iron setback and shaving thickness
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
