Re: "Planecraft"
Re: "Planecraft" ()
Patrick Chase
It's not clear to me what you're trying to imply. I would hope they agree, as it's a simple statement of incontrovertible fact.
If you plane a board with a well-tuned 60 deg plane (I have 62 deg frogs for a couple of my bench planes) you'll see that it produces full-length continuous shavings. The resulting surface is smooth, though not "glassy" as from a common-pitch plane. If you examine the surface under a microscope, as I have, you'll see that its structure has been cleanly cut for the most part (though again with more disruption than from a lower-angle plane).
Now plane the same board with an unhooked scraper of the sort that would be used for mouldings, in a scratch stock or similar. The shavings are "powdery" and much less cohesive/continuous. The surface quality is noticeably more "dull" and "fuzzy" at the macro level, and exhibits much greater structural disruption under the scope. It's not as bad as a sanded surface, but it's clearly the result of very different cutting mechanics than the plane.
If you honestly think that scraping and planing with a 60 deg plane are equivalent, then you've either never *really* looked at the results, or you don't know how to tune/use a plane.
Messages In This Thread
Cap iron setback and shaving thickness
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
