david weaver
Just in general (I built "thick iron" single iron planes before I saw Warren's double iron light):
Thick Iron:
Advantages:
* no chatter with long unsupported span (good for planes with wedges that terminate high on the iron or planes with lever caps). A plane of most designs with a 1/8th single iron will chatter. Maybe not in smoothing, but in most other things. The curators at Williamsburg concluded that chatter was just part of planing.
* stable in planes that aren't bedded perfectly - might be an advantage in a plane that moves
* really "solid" feel. they add to the weight of the plane, too - so the "feel" is probably a combination of two things.
* some people really like the aesthetic
Disadvantages (this is for single iron only):
* longer to grind (this eventually becomes annoying when you get used to thin irons)
* no practical way to maintain them only by hand if you want to do that (if we're talking about something like Knight's irons or Brese irons - which are both superb irons, by the way - Steve doesn't get as much press as he should for just how excellent his O1 irons were. They were hard without being brittle like the hocks.
* hard to profile if you want to do that
* tearout control requires high angle or tight mouth (mouth has to be really tight to really be effective - like 2x chip size, which may mean 4 thousandths or so for a smoother). Planes tend to be one-dimensional (e.g., a fine cutting high angle smoother with a very tight mouth or an open mouthed roughing plane)
(when you get the double irons that are a quarter thick and have a cap iron on them, they are solid feeling, but they feel really awkward at the same time - not important I guess)
Thin Double Iron
Advantages:
* quick to grind the iron and the iron can be ground by hand easily if you'd like
* generally cheaper to buy
* easily profiled
* gives a plane a very wide range of working capabilities (fine or coarse with the same plane). I single plane can literally smooth anything once you learn the function of the cap
* adding an adjuster can be done cheaply
* excellent tearout control with a cap iron, as good as anything short of a card scraper and sandpaper. Chatter free in all but the very heaviest cuts (you may still get a tiny bit of it if you set a plane up as a fore and really horse it, but it's the kind of chatter that doesn't matter, and it might actually help make the cut easier. I'd define bad chatter on a heavy cut as the kind that keeps the plane from staying in the cut).
* a bit more forgiveness in plane setup. If the iron is held firmly at the back of the bevel, the top of the cap iron and the top of the iron at a point, it will probably work well and without tearout. The same is true of single irons, but it's a bit harder to hold them close to the point of cut (in terms of plane design)
Disadvantages
* fitting and learning the double iron
* any deep pitting in an iron can be the end of it (hopefully that doesn't occur)
* Not forgiving of major fit problems with a plane, and the plane design still needs to support the cap iron relatively close to the mouth (e.g, where the lever cap meets the hump on a stanley cap iron)
Messages In This Thread
Cap iron setback and shaving thickness
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
