Re: McGuire
Maguire ()
david weaver
That is a perfect example. Because the internet often wants TL/DR resolution for us not to have follow up posts, and patrick, you and I are perfect examples because we tend to go all the way to the bud on the farthest branch on the tree before we stop - I didn't say it clear enough about that.
Warren is the only person who gave good advice about it. That's it. "as good as" (fill in the blank, sanding, high angle, etc) doesn't really suggest someone mastered it (go back again then to the person who only uses a plane for surface prep - perhaps to them, all of the options are similar).
That's not to say that someone isn't working in a shop somewhere and doing so without the internet and doing the same thing as Warren. It is just extremely unlikely that there is more than a few of those someones.
I can slice things in a million directions:
"how many people actually working by hand gainfully like warren without supplemental income" (very few)
"how many of those folks aren't using japanese planes and didn't follow nakashima or something similar"
"how often do you see a cap iron on a used plane that looks like it was in use the last time it was put away". I have seen exactly zero, despite buying planes that were actually in use, including infills from luthiers. I was a bit surprised at their level of setup, but maybe they were always scraping by preference. Who knows?
We get down to very few. Warren often talks about "advances" in woodworking draining the skill from the profession to replace it with unskilled labor. I think this is one of those places. It was "advanced" out, even in warren's neck of the woods where he's surrounded by woodworking that's still going.
My thoughts are like Steves - it's not that it was completely lost, I can't believe that would be the case (plus, warren and the two Finns just to start - using it without the internet telling them to). It's just there are lots of woodstock attendees and out of shape lackeys with Navy Seal Tattoos.
Messages In This Thread
Cap iron setback and shaving thickness
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
