Tried this again today
david weaver
I haven't been in the shop in a while, and was in it this morning to repair some drawers that someone dropped off.
I broke out the #4 and found a stick of beech a little over an inch wide, quartersawn (so the edge is the same as the face of a flatsawn board).
On the edge of a beech board, I'm just not able to get close to having the cap iron even with the sole and getting something manageable. At that point, I can still take a shaving with much struggling, but it's not possible to start the cut smoothly without skipping. On the face of a board with a wider cut, it would really be a problem.
I don't have a novel way to measure the projection (I suppose I could put it under the scope and photograph a wire of known diameter with it to guesstimate, but I'm pretty sure I was well short of even with the sole).
Beech is relatively dense and even and that may make getting the cap even with the sole a taller order. I didn't have any longer planes handy in the shop, just metal smoothers and wooden long planes (which is what I generally work with).
I'm curious to find out if anyone else has tried this.
(the smoother I'm using is generally stock angle on the cap iron plus whatever it may have increased when I cleaned it up and honed it).
Messages In This Thread
Cap iron setback and shaving thickness
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
