david weaver
I'd be curious to find out why he thought the radius was an advantage.
If Patrick confirms that he was measuring shaving thickness and not the reduction in board thickness, he's still going to come to the conclusion that he's not using the cap below the sole, and even at the sole is a recipe for fuzzy wood.
re: nicholson, there's no guarantee that every single thing in his book is optimal. Certainly on the whole, it's far above where I'll ever be, and perhaps I know one person who I'd rate at his level (George) as a craftsman.
I'd be willing to defer on the radius in a non-flat sole or as a matter of solving feeding problems in less than perfect planes, but as a matter of tearout reduction, it's functionless, and potentially backwards. But maybe not materially enough so that anyone would notice the difference (as in, the shaving thickness at the corners is thinner, and that can cause feed problems if a plane isn't properly set).
That said, if you can't tell me why it's better (to radius the cap), i'm inclined to believe I'm right in this case, or at the very least, not materially wrong. A vague explanation or reliance on craftsman's subtlety isn't going to suffice. Proving why the cap iron is such an advantage (especially if we go beyond just smoothing) has not been very difficult to explain or prove.
Perhaps you can elaborate to me why a thinner shaving spanning the same distance to the cap iron is better than a distance that varies based on shaving thickness.
(we don't see this radius on any japanese planes, either - but they wouldn't have the corner feed problem, because the cap iron is between the abutments and not under it - and to be honest, I haven't seen a lot of old japanese planes with much radius, but the ones I have gotten have been in such disrepair that maybe they were last used in rough construction).
Messages In This Thread
I knew *PIC*
Re: I recall
By the way, Mark..
Re: By the way, Mark..
planing
Re: planing
Re: planing
Re: planing
Re: planing
Re: planing
Consumables vs skilled labor
Re: Good Work
Tried this again today
Re: Tried this again today
Double Iron vs. Thick Iron
Not really lighting it up
Correction
Re: Correction
Re: Correction *LINK*
Re: Correction
Cap iron sharpening
Re: Cap iron sharpening
Cut depth, species, and wear
Re: Worn Through
Re: Worn Through
Pictures *PIC*
Re: Pictures
Re: Pictures
Re: Pictures
Cap iron sharpness
Re: Cap iron sharpness
swingley thread
Blackburn
Re: Blackburn
Re: Blackburn
Andrew Hunter
Japanese planes
Re: Japanese planes
Re: Japanese planes
Re: Japanese planes
Set-back distance and measurebation
Re: Correction
Re: YMMV
Re: YMMV
Re: YMMV
Re: Correction
Re: Correction
Re: Correction
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Re: The most likely
Jupiter Cakes
Re: Jupiter Cakes
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
Re: Correction
This seems pointless
Re: This seems pointless
"Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
The big difference
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
My apologies
Re: Burr and Hardness
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Re: "Planecraft"
Maguire
Re: Maguire
Re: Maguire
Re: Maguire
Re: Maguire
The Virtue
Re: McGuire
Re: Correction
Re: Correction
Contrariness
Remarkable restraint
Re: Remarkable restraint
Re: Contrariness
Kato and Kawai
Re: Kato and Kawai
Re: The other issue...
Re: And a quote....
If you're a beginner...
Redoing the test
Re: Redoing the test
