Re: Do you profile your cap irons?
Patrick Chase
Do you do anything special to ensure that the corners of the cap iron mate firmly?
The reason I ask is because the mating surface of the cap iron is typically undercut a bit, so if you just camber the leading edge and don't make any other adjustments, then in theory the corners will lift off by (camber_depth*tan(undercut_angle)).
I say "in theory" because the amount is fairly small. For example with 3 deg of undercut and 1/32" camber you would see ~1.5 mils of "lift" at the extreme corners, which may or may not be worth worrying about in a roughing plane that takes much thicker shavings than that.
Obviously you could fix it by investing some quality time with some marking grease and a slip or by taking the relief angle down as low as you dare, I'm just curious to know if you bothered.
Messages In This Thread
Whelan planemaking book?
Re: Whelan planemaking book?
Re: What is the title
Thanks Patrick *NM*
Dimensioning: Question about roughing planes
Re: Dimensioning: Question about roughing planes
Reference: Peter Nicholson, 'The Mechanic's Compa
Re: Reference: Peter Nicholson, 'The Mechanic's C
Re: Reference: paragraphs 3 and 4 *PIC*
Errors or suboptimal statements in books
Everybody makes mistakes
Things that can be out of date, too
Re: Everybody makes mistakes
Peter Nicholson plate XII, pages 91 to 93 *NM*
(Message Deleted by Poster)
No worries *NM*
Fun with math
Where did the ball go?
Focussing on the key point
Re: Focussing on the key point
Re: Where did the ball go?
Nicholson
Nice Article!
Re: Nice Article!
Re: Whelan planemaking book? *LINK*
Thanks (NM) *NM*
Can't answer about the Whelan book
