Do you profile your cap irons?
Patrick Chase
Do you profile your Jack's cap iron to "follow" the camber of the iron, or leave it straight and set it back far enough to avoid overlapping the corners?
I do the latter, mostly because I don't want to compromise mating at the leading edge of the cap iron (if you camber avcap iron then its corners may lift up a bit due the the undercut on the cap iron mating surface).
My most aggressively configured Jack has ~0.06" of camber, which in turn means that the minimum cap iron setback is at least that much in the center. It doesn't seem to buy me all that much in that configuration.
Messages In This Thread
Whelan planemaking book?
Re: Whelan planemaking book?
Re: What is the title
Thanks Patrick *NM*
Dimensioning: Question about roughing planes
Re: Dimensioning: Question about roughing planes
Re: Do you profile your cap irons?
Reference: Peter Nicholson, 'The Mechanic's Compa
Re: Reference: Peter Nicholson, 'The Mechanic's C
Re: Reference: paragraphs 3 and 4 *PIC*
Errors or suboptimal statements in books
Everybody makes mistakes
Things that can be out of date, too
Re: Everybody makes mistakes
Peter Nicholson plate XII, pages 91 to 93 *NM*
(Message Deleted by Poster)
No worries *NM*
Fun with math
Where did the ball go?
Focussing on the key point
Re: Focussing on the key point
Re: Where did the ball go?
Nicholson
Nice Article!
Re: Nice Article!
Re: Whelan planemaking book? *LINK*
Thanks (NM) *NM*
Can't answer about the Whelan book
