Re: What doesn't result in a hand tool look
Well, yes if you want to make the handtool look obvious, you need to add some typical design elements that are best done by hand and try to put a bit of "schwung" into it.
Then there are of course the hidden clues, like the rough backboards, the gaping shoulderlines on the inside, the secondairy wood like pine, all those things you see in antique cabinets.
And then there are the subtle clues like Brian described, the wood choice, how the wood is used, the panel thickness etc.
Kees, this is what I have difficulty accepting. Or perhaps I am misunderstanding your argument.
I do understand that furniture in the past (to which we are referring) was built without the need to thickness all board to the same dimensions, such as when making panels. I know and accept this because I have done so enough times in the past to be familiar with the process (in the days pre-thicknesser/planer). The different board thicknesses do not show on the outside.
The inside of this table ..
... is referenced by the outer edges. Inside is a multitude of thicknesses ...
I also understand that one will take less care with other areas that are not seen. Even on drawers that are carefully made and have the most precious dovetails at the front, sizing and gaps on the rear dovetails may be ignored of lesser concern ...
But .. but ... but ... what has this to do with a "hand tool look"?
I think that we need to stop talking about a "hand tool look" and instead ascribe the warmth you are seeking to be a function of design and construction rather than construction alone. The signs of building quickly/efficiently by hand that are evident on the inside of a carcase are not welcome on the outside - there they are simply "sloppy" to me.
A piece that is well made using hand tools imparts a subtle variation in line, and this is charming, and for myself it is a desirable feature, however the warmth you speak of I believe comes from the design, per se. Take that dining table of yours: Your table is very angular, all straight lines. What could you do to soften this? Would it change if you planed the top with a hand plane?
I'm going to continue this conversation in a post of its own since I wish to illustrate this argument with an actual build. I am finishing off design preparations for the next piece, and I hope to post this soon.
Messages In This Thread
What makes the "handtool" look?
David Pye's thoughts
ICBM gyros
Confusion
Re: Confusion
Pye
Re: David Pye's thoughts - Just not true though
Visual vs. measurement
Further thoughts
Re: Further thoughts
What doesn't result in a hand tool look *PIC*
Sorry, didn't read your post very well
You said it well *NM*
Affectation Vs. Artifact
Re: Affectation Vs. Artifact
Virtue?
Re: Virtue?
Re: Virtue?
Re: Virtue?
Re: Virtue?
Re: Virtue?
Thanks gentleman
Where was "why bother"?
Caring WRT Handwork
Re: Caring WRT Handwork
Re: What makes the "handtool" look?
Re: What makes the "handtool" look? Mistakes?
Easy... the eye of the beholder
You guys are way too negative
Perhaps...
Re: Perhaps...
Amish
Saw handles
Re: Saw handles
Easy question
A Riff on Derek's ideas
Thanks Todd. *NM*
Re: we do it for ourselves
Re: we do it for ourselves - Nietzsche nailed it
Wrong question
Re: Wrong question
Re: Wrong question
Re: Tempted
Re: Tempted
comment
Re: comment
Re: comment *PIC*
Re: comment (touchy feely alert)
ditto for turning
Re: comment
Re: comment
Re: comment
Re: comment on comment *PIC*
Not what I see *PIC*
Re: comment
I'm back to what is the objective
Re: I'm back to what is the objective
Re: I'm wondering ...
Re: comment
Re: comment
Re: comment
printing..
Re: comment
Disagree
This is a line of thought often
Where is Adam Cherubini ?
Re: Where is Adam Cherubini ?
Adam's goal, as expressed to me
Chamfers on rails and styles
Edit: incomplete thought.
What is the objective
Re: I don't really know
If you can't design then copy
Re: If you can't design then copy
Re: That is a line...
