john Lucas
I use the scary sharp system of gluing sandpaper to glass. Since I'm a wood turner this doesn't get used a lot. Every now and then I do flat wood project and need to touch up my hand planes or chisels. I use 3M super 77 spray and it's always hard to get the sandpaper off when I need to replace it. Anyone have a better idea. Right now I use 4"x 10" pieces of glass as my substrate and cut the sandpaper to fit.
A second question. I sharpen to 1500 grit and then go to the strop. Is that where you guys stop. My chisels seem quite sharp and will shave hair easily. I did find some 2000 grit paper and wonder if I should go that extra step. It would require finding some more glass.
If you want the ultimate sharp edge (I'm thinking carving tools) what method would you use.
Messages In This Thread
- Scary sharp sandpaper glue
