Planing and edge stabilization
Wiley Horne--So. Calif.
Hi Derek, Sir Wm. and all,
My take on Andrew's comment to the effect that planes 'can't get sharp enough', was that he was dealing with very thin veneer, like 1/32" or less, or maybe 1/16. When the veneer gets up to 3/32 to 1/8, it'll plane just fine (super sharp is assumed). See below on mini-chipping at the edge.
One thing I found when using a plane to edge joint or edge plane 1/8" satinwood veneer recently was that coatings of hide glue on the end grain, and shellac on the face grain, stabilized the edges against spalling off little chips. To explain: After I joined the veneer to make up either the main field or the cross-banding, I left a coating of glue on the edges as a sealant--if you don't do that, water loss through the end grain will cause the seams to open up (in our dry weather). Also, the bottom of the veneer was left glue-sized. In addition, I put shellac on the appearance face to protect against miscellaneous dings and dirt. When it came time to do the final edge planing prior to glue-down, it turned out that the combination of hide glue and shellac stabilized the edges very effectively against chipping. It planed dead clean.
Later when it was time to cut channels on either side of the edge banding for stringing, I was able to scratch clean channels cross-grain with a simple ploughing tooth. Started the cut down through the shellac and glue at a low angle. Did not have to use a sawtooth type scoring tool. In trials, I found the direct cross-grain scratch to be cleaner than the LN sawtooth tool cut--probably my technique with the sawtooth, but anyway that's why I went with the direct ploughing.
OT Note: In sawing the veneer, mostly I used a panel-type saw (convex cutting edge) against a ply straightedge. Once I bandsawed it cross grain, used the bandsaw to speed up a bunch of repetitive cuts, and in that case, it was vital to make those sawcuts in a sandwich between two pieces of sacrificial scrap to avoid major chipping (DAMHIKT).
Wiley
Messages In This Thread
The Veritas Shooting Plane - Reviewed
An OT question
Re: An OT question
Re: An OT question
Just furniture? :D
Re: An OT question *LINK*
Re: An OT question
Re: An OT question
Re: An OT question
Re: The Veritas Shooting Plane - Reviewed
Re: The Veritas Shooting Plane - Reviewed *PIC*
Thanks for the review
Re: Thanks for the review
Stanford deserves a compliment here
The eagle just swooped down..... *PIC*
Re: The eagle just swooped down.....
Negates much of the benefit of the skewed blade?
Re: Negates much of the benefit of the skewed blad
Not so ...
Derek is right
Varieties of ramped boards
Re: Varieties of ramped boards
There is something new under the sun
Another way to shoot veneer ..
Re: Another way to shoot veneer ..
Sandpaper shooting
Re: Or 99%
Re: Not so ...
Chiming in.....
Re: Rotator cuff
Re: Rotator cuff
Re: Rotator cuff
Thanks, Roger! *NM*
Re: Chiming in.....
Re: Chiming in.....
The way I see it
That's a pretty plane, Roger
Give it up, Fellas...
Methodology, I got a chuckle...
Funny, my take-away...
Re: On arrows
Shooting Star
Excellent review and discussion, Derek
A doddle?
Re: A doddle?
Re: A doddle = Bobz your uncle
Bravo, Derek! *NM*
