Re: more questions and problems chopping mortises
joel moskowitz
The mortise in question is pretty long and pretty deep. the one in the picture several inches in one case. the OP is using home made chisels where the geometry isn't correct. Real mortise chisels might be 3/4" in thickness at the bolster but are only 1/4" or 3/8" thick at the cutting edge which tapers in the primary bevel at 20 degrees or so until the secondary bevel so that they aren't thick and cumbersome at all at the tip. A 1" long mortise 1" deep is a snap to chop so is a 1/2" x 1/2 or 3/4". A deep 1/8" mortise is also pretty easy.
A lot of the problem here is that in pursuit of ultra long lasting cutting edges the OP sacrificed the rest of the geometry that makes the chisel work.
We are the only seller of traditional English Mortise chisels in the US. I have always thought in the days when that was all that was there a poor compromise. I put together my set of mortise chisels during trips to the UK in the early 90's.
Messages In This Thread
more questions and problems chopping mortises *PIC*
Grain direction *PIC*
you are right about the wood
Possible "bindy" explanation
Re: Possible "bindy" explanation
Traditional chisels
A picture or drawing please
Re: Traditional chisels
Dark Ages
Re: Dark Ages
Re: Dark Ages *PIC*
Re: Dark Ages
All assumptions incorrrect
Re: All assumptions incorrrect
Something whacko with the wood
Re: Something whacko with the wood
If it were me, and I could make a.....
a compelling thought
just a thought
Re: just a thought
