Steel and Tools
Don't forget the obvious - that steel and tools are two separate items. If you are already stocked for tools, then you will not be planning to add more, regardless of the steel composition of the new tools.
On the other hand, you may decide the new tool is an upgrade, or the new steel is an important time saver.
I do not plan to replace all my blades with PM-Vlll just because it is better (and it is). That would be silly. However, the next time I purchase a blade, it will definitely be made of PM-Vlll steel. It would be silly not to do so.
I only have first hand experience of one PM-Vlll plane blade, which is used in a Veritas Small BU Smoother. This was put through a great deal of testing about 12 months ago. On the basis of this I can state that, using Pro Shaptons, the PM-Vlll blade honed about as quickly as an A2 equivalent, and lasted about twice its duration planing abrasive Jarrah boards (yes, I stood there counting shavings).
I have not used PM-Vlll in chisels. The PM-lll was a late entry into the chisel testing conducted nearly 2 years ago. Steels included M4 and 3V, and the PM-Vlll was chosen above these. I did, however, use the steel with a 25 degree bevel to shoot Jarrah endgrain later on. It held up very well. According to Rob Lee it can be used at 15 degrees ... which would make for an interesting paring chisel!
Messages In This Thread
Might as well start the LV PM-V11 Thread
Re: Might as well start the LV PM-V11 Thread
Re: Inside Joke / story
Japanese steel and PM V11 *LINK*
more picking on Kees
Re: more picking on Kees
Re: PM V11 and LV sharpening mastery + the truth
Where were all you sages back then.....?
Re: Where were all you sages back then.....?
Finck
comparing apples and oranges
Re: comparing apples and oranges
Modern steel
Re: Modern steel
Proposed amendment to Kee`s post
Re: Proposed amendment to Kee`s post
data to disagree with your conclusion *PIC*
Drawing a conclusion
minor corrections
Re: minor corrections
A purveyor of CPM 3V chisels
working porperties of 3V
Some people`s reasoning stumps me
Re: Some people`s reasoning stumps me
that was the conclusion I came to
Re: data to disagree with your conclusion
Chisels don't quietly wear away.
Re: Chisels don't quietly wear away.
Flaw in Woodcentral Web site/PIC added *PIC*
Re: Flaw in Woodcentral Web site/PIC added
Swiss steel?
Shut your festering gob, you nit!
Re: Shut your festering gob, you nit!
Re: Shut your festering gob, you nit! *LINK*
the brass weight..
can you believe that there are people
Re: can you believe that there are people
Re: If you have a stake..
Don't read too much into that, Curt
Steel and Tools
Re: Steel and Tools
Re: When you throw out the holteys...
Of course...
Re: Of course...
I did not sneer
Re: I did not sneer
Re: I did not sneer
Re: I did not sneer
Re: I did not sneer
Re: I did not sneer
Well..
Re: Well..
Re: Well..
Re: The News
Excellent analysis *NM*
Re: Not me, dude...
Re: Not me, dude...
Missing the point
Re: I was going to wait a while..
I too subscribe to your rule
Re: I too subscribe to your rule
It's new !! so what
