Re: Larry, you haven't been totally dismissed..
david weaver
Yeah, heat tolerance is probably the biggest day to day change.
But it's uncanny when you get something cocobolo that is really bad in terms of silica content, it can dull a carbon steel plane in 10 strokes. I can get 100 or more out of an HSS planes.
But what those numbers look like with something like cherry, is probably more like a factor of two to three, and vs. A2 in cherry, maybe a factor of 2 or a little less.
But in cocobolo that is really nasty with silica, A2 and HCS are hard to use.
Messages In This Thread
Revisiting various abrasion(dulling) mechanisms
Re: Revisiting various abrasion(dulling) mechanism
Friction isn't the cause of the heat
Re: Friction isn't the cause of the heat
Reply
Re: Friction isn't the cause of the heat *PIC*
you need a trip to Steve Elliott's web site
calling Sherlock Holmes
Re: calling Sherlock Holmes
Making the Wear Profile Test Images
replied off line *NM*
no, the oposite
Re: no, the oposite
heating
heat
I'm interested...
Re: I'm interested...
Re: I'm interested... - goog point
Abrading steel alloys
May I make a suggestion?
Good points, well said. *NM*
+1 *NM*
Re: May I make a suggestion?
User wear spiraling out of control.....
Tool Wear vs tool geometry *PIC*
Re: Tool Wear vs tool geometry
Kato and Kawai shed some light
