Re: Larry, you haven't been totally dismissed..
craigd
David writes ..I've read the discussion with some interest, because I can't otherwise explain why my HSS planes last so many multiples longer
I could be blowing smoke but I believe that HHS is more rust/corrosion resistant than O1 which may possibly be a [probably quite small] factor. The more obvious factor is HSS was designed to be more durable in machining applications (as well as tolerating much higher heat, if heat is a factor).
Messages In This Thread
Revisiting various abrasion(dulling) mechanisms
Re: Revisiting various abrasion(dulling) mechanism
Friction isn't the cause of the heat
Re: Friction isn't the cause of the heat
Reply
Re: Friction isn't the cause of the heat *PIC*
you need a trip to Steve Elliott's web site
calling Sherlock Holmes
Re: calling Sherlock Holmes
Making the Wear Profile Test Images
replied off line *NM*
no, the oposite
Re: no, the oposite
heating
heat
I'm interested...
Re: I'm interested...
Re: I'm interested... - goog point
Abrading steel alloys
May I make a suggestion?
Good points, well said. *NM*
+1 *NM*
Re: May I make a suggestion?
User wear spiraling out of control.....
Tool Wear vs tool geometry *PIC*
Re: Tool Wear vs tool geometry
Kato and Kawai shed some light
