Re: Revisiting various abrasion(dulling) mechanism
Sgian Dubh
Bill, I'm not sure I really understand what's driving you on this. Is it perhaps just an urge to get to grips with the subject for the sake of it, or is there a practical application you're looking for at the end?
In my case I don't find a need to investigate abrasive much.
A sharpening stone will sharpen my plane irons and chisels, and abrasive paper wrapped around a cork block sands the wood. Files cut metal, and rasps tear up wood.
None of it causes me much angst and so far in life the products I can buy off the shelf are effective enough to keep me planing, chiselling and sanding wood as fast as I need to. Other people have done the work required to supply me with abrading tools-- I just buy them and use them as needed. Slainte.
Messages In This Thread
Revisiting various abrasion(dulling) mechanisms
Friction isn't the cause of the heat
Re: Friction isn't the cause of the heat
Reply
Re: Friction isn't the cause of the heat *PIC*
you need a trip to Steve Elliott's web site
calling Sherlock Holmes
Re: calling Sherlock Holmes
Making the Wear Profile Test Images
replied off line *NM*
Re: Larry, you haven't been totally dismissed..
no, the oposite
Re: no, the oposite
heating
heat
I'm interested...
Re: I'm interested...
Re: I'm interested... - goog point
Abrading steel alloys
May I make a suggestion?
Good points, well said. *NM*
+1 *NM*
Re: May I make a suggestion?
User wear spiraling out of control.....
Tool Wear vs tool geometry *PIC*
Re: Tool Wear vs tool geometry
Kato and Kawai shed some light
