Re: Revisiting various abrasion(dulling) mechanism
Bill Tindall
Unless one can identify something in the wood structure that has a greater tensile strength than the steel cutting it then adhesive wear can be dismissed as a relevant mechanism.
The mineral content could provide abrasive wear. The volatiles and extractives could promote corrosive wear.
As Kato and Kawai demonstrated factors that increase shaving pressure promote wear in the high pressure areas. One does not have to conjure different wear mechanisms to explain the different amounts of wear observed at different rake angles relative to the grain orientation. These results can be rationalized by the difference in shaving pressure on the blade tip.
Messages In This Thread
Revisiting various abrasion(dulling) mechanisms
Friction isn't the cause of the heat
Re: Friction isn't the cause of the heat
Reply
Re: Friction isn't the cause of the heat *PIC*
you need a trip to Steve Elliott's web site
calling Sherlock Holmes
Re: calling Sherlock Holmes
Making the Wear Profile Test Images
replied off line *NM*
Re: Larry, you haven't been totally dismissed..
no, the oposite
Re: no, the oposite
heating
heat
I'm interested...
Re: I'm interested...
Re: I'm interested... - goog point
Abrading steel alloys
May I make a suggestion?
Good points, well said. *NM*
+1 *NM*
Re: May I make a suggestion?
User wear spiraling out of control.....
Tool Wear vs tool geometry *PIC*
Re: Tool Wear vs tool geometry
Kato and Kawai shed some light
