Kees
That kinda explains why I never had much luck with a close mouth on a 45 degree plane.
The plane with the finest mouth I possesed was the Stanley #4 with a Ray Iles iron. When I bought that iron, I had to file the mouth because the iron was too thick. With some carefull filing I managed to get a mouth, which passed a 0.2mm feeler blade, but not a 0.25mm one. In US meassurements, that's between 8 and 12 thou. For me that was a very narrow mouth.
I have been planing 4 thou shavings a lot lately. Just using that fine mouth didn't help to mitigate tearout. 4 thou shavings isn't a very thin shaving. So, as a conclusion, my mouth was way too wide. I should have moved the frog a little bit. Problem with moving the frog on a Stanley plane: that's not a very precise operation.
Anyway, all that is history now. In order to be able to use the capiron without clogging issues, I grabbed a file last weekend and enlarged the mouth considerably.
I think we can safely assume you can't use the capiron close at the edge, and a mouth narrow enough to prevent tearout, at the same time.
Messages In This Thread
- Kato and Kawai and fiddly adjustments
- Re: Kato and Kawai and fiddly adjustments *PIC*
- More thoughts on how the mouth works
- Re: More thoughts on how the mouth works *PIC*
- You are correct
