Put your legs into the saw stroke
wilbur
I don't have a great handle on long rip cuts with a Japanese saw. It's like the final frontier of sawing for me, and quite honestly I think that's why God invented bandsaws. :D
But there are some things that I've tried that seem to help, although I don't know if they are at all traditional.
First, sawing on low horses is the way to go, unless your bench is ridiculously low. I know you have problems with your back, so try different heights. Maybe one will be more suited to you than another. It will be a very quick and easy job to prototype a low horse just to find a good height for you, and then you can build a nicer one.
Second, use two hands on the saw and use your legs. I find that sawing on low horses using arms only gets old fast, probably because I am out of shape. :D Regardless of why, I find that if you bend your knees slightly as you put the saw into position for a cut, and stand up slightly as you make the cut, you get a lot more power without giving up control. My guess is that if I put my legs into sawing, it's about 75% legs and 25% arms.
Again, I need to stress that I have no idea if putting your legs into it is traditional practice or not. But once I started doing that it seemed so effortless and natural that I think there may be something to it. Similarly, pulling a Japanese plane is as much about the legs and torso as it is the arms.
Messages In This Thread
Ryoba Ripping Remedy Requested
Update:
Kataba?
Re: Kataba?
Re: Kataba?
Re: Kataba?
Hardwood Set? *link*
P. S--Oh, that's Stu's site
Re: P. S--Oh, that's Stu's site
Thanks Stu,
Does someone have one?
Possible bench
(Message Deleted by Poster)
Re: If you have no other solution, ...
Building a bench without a bench
Do have something - can I make it work?
Said I wouldn't ask any more questions but...
Learning curve
Re: Learning curve - two solutions
Round Dog Sizes?
Re: Round Dog Sizes -- John Ross
Yes you can!
The Gladiator Stats for Wiley
Re: The Gladiator Stats for Wiley
Planing stops (lots of pics)
Re: Planing stops (lots of pics)
Depth for Hold Fasts
Couple more work holding ideas
Re: For that matter...
Re: Depth for Hold Fasts
Re: Depth for Hold Fasts & moxon
Re: Yes I can - later
Re: Just grab your boots and pull
Hand vs. band
Re: Hand vs. band
Re: Hand vs. band
Re: That makes total sense to me...
Re: Ryoba Ripping Remedy Requested
Never Mind, I misread your post *NM*
Oh and one important thing I forgot
Re: Oh and one important thing I forgot
Re: Front sight, front sight...
Re: Understood
Re: Ryoba Ripping Remedy Requested *LINK*
