Re: Myth
Re: Myth ()
Kees
Keep practising Joel ;-) 1/32" is 0.8mm. You can do better then that!
The trick is to use the light reflected from the back of the cutting iron. First you tighten the screw a little with your hand. Then you move the capiron into poistion. The narrow reflecing line indicates very well where you are. Then fully tighten the screw.
