Adding to the discussion.....
Bill Tindall
The Kato-Kawai pictures, as well as Steve Elliot's pictures, show us that the clearance angle at the blade tip becomes zero very quickly as a result of the bottom of the blade wearing as it rubs across the wood. Hence, much of the time we are planing with a zero microbevel. This wear surface eventually grows sufficiently large to creat a lifting force on the blade. I don't think I am up to trying to figure out the compensating forces of a lower blade angle and this lifting force from this wear surface. However, I once made a low angle Krenov style plane with very little clearance angle and it worked fine.
Messages In This Thread
Chip breaker experiment: session four
Re: Chip breaker experiment: session four
Interlocked grain *PIC*
Re: Interlocked grain
Adding to the physics
Re: Adding to the physics - a touch of commonsense
Re: Adding to the physics - pick up the pace
Effect of velocity
Re: Effect of velocity
depends on mechanical prop. of the wood fibers
Re: depends on mechanical prop. of the wood fibers
Is there a mechanical engineer in the house?
Re: Is there a mechanical engineer in the house?
skew angle *LINK*
You're right - I stand corrected.
That is a start
Wiley's work *NM* *LINK*
making knife jointing less worrisome
Re: high angle vs low angle
Recognizing Surface Quality
Re: Recognizing Surface Quality
Nice Picture!
Many ways to skin a cat
Re: Many ways to skin a cat
