Re: Interlocked grain
Re: Interlocked grain ()
Hi Mark
I agree with your comments about a smooth, flat leading edge to the mouth. If there are chips or depressions, then this can be a cause of tearout. If there are striations, it can affect the shaving (I am not sure if this is so here, because this is how Tasmanian Oak shavings typically appear).
It would seem to me that a high angle bed is going in the wrong direction, and would seem to me to be pushing and scraping the wood more than cutting. And although it may not cause tearout it is probably not going to give you as good a surface.
So looking at this from a logical, observational perspective, high bed angle never made any sense to me.
Having used supersurfacers and handplanes for many years,I am quite sure that low bed angle works quite well. So its not just an opinion without any backup.
I have many years experience using planes with high beds and/or high cutting angles. I understand the view that they scrape rather than slice. Nevertheless they can and do produce a very smooth, if not reflective surface, in hardwoods. In the Australian context, where especially in my neck of the woods, the local fare is interlocked and hard, high angle planes make a lot of sense.
What is old/new is the notion of using the chip breaker to control tear out in a common angle plane. While you say it is old - and I am not questioning this at all - for a great many woodworkers (ask the forum to raise their hands), this is something they have little or no experience in doing. Chip breakers were "cap iron" that only served to stiffen the vibration in a blade. That is, if the performance was improved by a chip breaker, it was because of reducing vibration, per se.
So we are to some extend rediscovering the wheel. However there is more to this than just that. We also know that other strategies improve the performance of planes on interlocked or reversing grain. And this experiment was intended to examine some aspects.
Messages In This Thread
Chip breaker experiment: session four
Re: Chip breaker experiment: session four
Interlocked grain *PIC*
Adding to the physics
Re: Adding to the physics - a touch of commonsense
Re: Adding to the physics - pick up the pace
Effect of velocity
Re: Effect of velocity
depends on mechanical prop. of the wood fibers
Re: depends on mechanical prop. of the wood fibers
Is there a mechanical engineer in the house?
Re: Is there a mechanical engineer in the house?
skew angle *LINK*
You're right - I stand corrected.
That is a start
Wiley's work *NM* *LINK*
making knife jointing less worrisome
Adding to the discussion.....
Re: high angle vs low angle
Recognizing Surface Quality
Re: Recognizing Surface Quality
Nice Picture!
Many ways to skin a cat
Re: Many ways to skin a cat
