Interlocked grain *PIC*
Warren in Lancaster, PA
No, on the contrary, I conclude that higher cutting angle is an important requirement in achieving good performance on interlocked, hard woods. However, the chip breaker is also a factor in improving performance. It remains, however wood dependent.
I have been using the double iron for interlocked grain for more than 35 years. The double iron plane was designed for this type of work. A high angle plane is unnecessary.
Here is what Samuel Carruthers wrote in 1767:
Messages In This Thread
Chip breaker experiment: session four
Re: Chip breaker experiment: session four
Re: Interlocked grain
Adding to the physics
Re: Adding to the physics - a touch of commonsense
Re: Adding to the physics - pick up the pace
Effect of velocity
Re: Effect of velocity
depends on mechanical prop. of the wood fibers
Re: depends on mechanical prop. of the wood fibers
Is there a mechanical engineer in the house?
Re: Is there a mechanical engineer in the house?
skew angle *LINK*
You're right - I stand corrected.
That is a start
Wiley's work *NM* *LINK*
making knife jointing less worrisome
Adding to the discussion.....
Re: high angle vs low angle
Recognizing Surface Quality
Re: Recognizing Surface Quality
Nice Picture!
Many ways to skin a cat
Re: Many ways to skin a cat
