Re: Experimenting with chip breakersResponse To:
Experimenting with chip breakers () Charles
When I run a chipbreaker way down close I do, and always have, produced an excelsior-like fluff (similar to your photos) and not distinct shavings. Sometimes this results in a great surface sometimes it does not.
This seems to be true across a variety of planes - I get the same thing with a Record No. 7 with a Hock iron and Clifton Stay Set cap iron. Get virtually the same thing with an old Record 4 with a 'best crucible cast steel' cutter and stock chipbreaker and stock lever cap. Same with an ECE 50* smoother with stock cutter and chipbreaker.
The mouth is closed down really tight on both smoothers, not so tight on the No. 7.
Messages In This Thread
- Experimenting with chip breakers
- Re: Experimenting with chip breakers
- Double irons *PIC*
- I did the Japanese someone else can do French
- The translation
- Re: The translation
- How does a toothing plane work to prevent tearout
- I'm on it!
- Re: I did the Japanese someone else can do French
- Re: Double irons
- The translation
