Re: A grinder and two stones..
david weaver
The spydercos you have are well regarded everywhere. They are a strange bird in the world of stones because they're intended to be used dry and without flattening, but I know of at least one world-class (and then some) craftsman who thinks really highly of them and uses them as his regular stones.
HSS (and by that, I mean M2 or more resistant than that to abrasion) likes to have a friable abrasive, like you'd have on a grinding wheel or a softer stone. Most stones that release grit slowly, unless the grit is diamond, load with HSS or don't cut it fast enough. Just my opinion. I have two, er....three HSS planes. I sometimes sharpen them with stones (having ground them accurately so that I don't have to work a lot of metal) and the shaptons work fine, but I wouldn't want to have only HSS tools and hard stones.
high hardness A2 cryogenic steel cuts slower on a stone than something like a vintage high carbon plane iron, but it's not a problem for any modern stone to handle A2 and high carbon, regardless of the hardness. It's the true high speed steels that favor something different if you have to sharpen them all the time.
I personally don't like HSS for planes that are intended to leave a finish surface, and I don't use them unless it doesn't matter or unless I am dimensioning an infill out of cocobolo or something (which isn't often).
I'd rather avoid them until at least the time that 3v becomes popular and cheap.
The razor hones you have (i'm assuming that's what they are) could be in a range from 4000 grit all the way to probably 15000 grit, and they can wear on the surface or be used with a lather, unless they have a label or print on them that says to use them with oil. Since they don't release grit, even the 4000 stone can become a very fine polish stone with use. If you have one that says "swaty" on it, it'll be very fine. If you have one that's a yellow color and says "Frictionite" on it and american hone, olean NY, I would think about setting it aside and not using it on tools (because they are worth a lot of $$).
Messages In This Thread
Sharpening jig/grinding question
Re: Sharpening jig/grinding question
Re: the scots
Sharpening jig/grinding answer
Re: Sharpening jig/grinding answer
Re: Efficiency
Efficiency rarely a consideration on this Forum
Very well said. *NM*
Razor hone questions
Sent you an email, Bill *NM*
Two most useful sharpening tools you can buy
Re: Two most useful sharpening tools you can buy
Amen to the hand lens *NM*
Good points, well stated. Diplomatic, even. *NM*
recommend that lens again.......
Funny you should compare it with your B&L *LINK*
You bet, Bill. Glad you like yours. *LINK*
Re: You bet, Bill. Glad you like yours.
at least sharp enough
Re: You could be plenty sharp to finish plane...
Re: Efficiency
Re: Efficiency
"Riding" hollow bevels on flat sharpening media
Whatever, but it's not inefficient. *NM*
Re: Tradtional Archery
Re: Good analogy! *NM*
Which came first...
Re: Which came first...
Full bevel
Re: Full bevel
My Method
TAANSTAFL
ADMIN! A reminder about civility
Re: A reminder about civility
didn't really answer my question
Re: didn't really answer my question
Flat bevel
Re: Flat bevel
Re: Flat bevel
Re: Flat bevel
chisel wear
Re: Flat bevel
Re: Flat bevel
We have been discussing this topic for years
Re: We have been discussing this topic for years
Sorry, I don't run your tests on command. Bill? *NM*
Re: Sorry, I don't run your tests on command. Bill
Smarm?! Hey, Bill, is this what you had in mind? *NM*
LV's plane blades, as shipped are sharp. *NM*
Yes, that's pretty much it
