A reminder about civility
As Wayne Miller of Badger Pond used to say, this is here because it has to be somewhere - that is, not pointing at anyone in particular.
I sure didn't know my question was going to trigger such a wide-ranging discussion; it's been interesting to see how many different issues the sharpening task can raise. By and large, this group's great about discussing, disputing, and analyzing ideas. I suspect there are about a million paths leading to the mountain peak of sharpness, and the conversations about the pleasures and hazards of these paths are often illuminating. Bill Tindall even took a minute to write me a side message encouraging me to try freehand sharpening again, and I appreciate his efforts to convince me and acknowledge that I do need to re-examine my sharpening practices.
Some - a few - of us have let the vigor of the discussion push into uncivil responses. In my observation, two things trigger rudeness here: you (this is an abstract "you") think someone's said something that attacks you personally; or you think someone's said something that's wrong, wrong, wrong and bullheaded to boot, and you need to Correct It Right Now.
If you find your emotions getting riled, please do take a breath and reconsider before you post a hot message; maybe step away from the computer and come back later, when you can respond more calmly and with the respect that is typical of this community.
Messages In This Thread
Sharpening jig/grinding question
Re: Sharpening jig/grinding question
Re: the scots
Sharpening jig/grinding answer
Re: Sharpening jig/grinding answer
Re: Efficiency
Efficiency rarely a consideration on this Forum
Very well said. *NM*
Re: A grinder and two stones..
Razor hone questions
Sent you an email, Bill *NM*
Two most useful sharpening tools you can buy
Re: Two most useful sharpening tools you can buy
Amen to the hand lens *NM*
Good points, well stated. Diplomatic, even. *NM*
recommend that lens again.......
Funny you should compare it with your B&L *LINK*
You bet, Bill. Glad you like yours. *LINK*
Re: You bet, Bill. Glad you like yours.
at least sharp enough
Re: You could be plenty sharp to finish plane...
Re: Efficiency
Re: Efficiency
"Riding" hollow bevels on flat sharpening media
Whatever, but it's not inefficient. *NM*
Re: Tradtional Archery
Re: Good analogy! *NM*
Which came first...
Re: Which came first...
Full bevel
Re: Full bevel
My Method
TAANSTAFL
ADMIN! A reminder about civility
Re: A reminder about civility
didn't really answer my question
Re: didn't really answer my question
Flat bevel
Re: Flat bevel
Re: Flat bevel
Re: Flat bevel
chisel wear
Re: Flat bevel
Re: Flat bevel
We have been discussing this topic for years
Re: We have been discussing this topic for years
Sorry, I don't run your tests on command. Bill? *NM*
Re: Sorry, I don't run your tests on command. Bill
Smarm?! Hey, Bill, is this what you had in mind? *NM*
LV's plane blades, as shipped are sharp. *NM*
Yes, that's pretty much it
