Re: Flat bevel
Re: Flat bevel ()
david weaver
try it and let us know what you find. Mortise properly (no scraping the edge), chop dovetails properly, etc, until you have an edge that you feel isn't sharp enough to do what you want it to.
Do the same thing with plane iron. Cut with it until you feel like you would sharpen it.
Then look at the two under a loupe (you won't even need to look under a loupe to see the wear on the plane iron edge, you can see it with the naked eye if the iron had a good polish at the edge to start). There may be a scratch or two on the chisel, but there will not be a pronounced wear bevel like you'd have on the plane.
So, try it, let us know. It's only as important as you want it to be because it's no more practical to know how a tool wears than it is to just have good tools that perform well for you and to like and use them. The wood doesn't know if you know why the edge will fail, and it doesn't care, so it's up to you and your curiosity to prove or disprove what I said above.
From an overall standpoint, it does matter if someone decides they want to find a super wear resistant steel to make chisels over a hand forged high carbon steel. The wear resistant steel will be a bigger nuisance to sharpen, so before someone decides they want to make a chisel with the most wear resistant steel they can find, they ought to figure out if it's abrasive or adhesive wear that's causing the chisel to feel dull after a lot of use.
Messages In This Thread
Sharpening jig/grinding question
Re: Sharpening jig/grinding question
Re: the scots
Sharpening jig/grinding answer
Re: Sharpening jig/grinding answer
Re: Efficiency
Efficiency rarely a consideration on this Forum
Very well said. *NM*
Re: A grinder and two stones..
Razor hone questions
Sent you an email, Bill *NM*
Two most useful sharpening tools you can buy
Re: Two most useful sharpening tools you can buy
Amen to the hand lens *NM*
Good points, well stated. Diplomatic, even. *NM*
recommend that lens again.......
Funny you should compare it with your B&L *LINK*
You bet, Bill. Glad you like yours. *LINK*
Re: You bet, Bill. Glad you like yours.
at least sharp enough
Re: You could be plenty sharp to finish plane...
Re: Efficiency
Re: Efficiency
"Riding" hollow bevels on flat sharpening media
Whatever, but it's not inefficient. *NM*
Re: Tradtional Archery
Re: Good analogy! *NM*
Which came first...
Re: Which came first...
Full bevel
Re: Full bevel
My Method
TAANSTAFL
ADMIN! A reminder about civility
Re: A reminder about civility
didn't really answer my question
Re: didn't really answer my question
Flat bevel
Re: Flat bevel
Re: Flat bevel
Re: Flat bevel
chisel wear
Re: Flat bevel
Re: Flat bevel
We have been discussing this topic for years
Re: We have been discussing this topic for years
Sorry, I don't run your tests on command. Bill? *NM*
Re: Sorry, I don't run your tests on command. Bill
Smarm?! Hey, Bill, is this what you had in mind? *NM*
LV's plane blades, as shipped are sharp. *NM*
Yes, that's pretty much it
