Re: Flat bevel
Flat bevel ()
david weaver
Warren, if you mortise a plane or something out of hard maple, you will see tiny chips in the edge if you look at it with light and magnification. If you do not, then I would assume that you are diddling through the process, or you're not using a chisel to do that to begin with.
That comment was probably in response to someone who was discussing the need for wear resistance in chisels. I don't see the need for wear resistance. I think you're confusing how large of chips I'm talking about, and if you don't see them, it would be because you've never had the occasion to use a chisel heavily or perhaps you've not looked closely at an edge under some magnification. Perhaps I should've described the size of the chipping earlier. If anyone is looking at the edge of a chisel and seeing nicks with the naked eye, then either the chisel is garbage or the user is abusing it.
I guess I don't follow how you can't keep an edge in the same shape with a hollow grind. There are two routes you can go with a hollow, I can tolerate either of them, they are both quick, and the second would not decrease the "intimacy" you're talking about, nor would it keep you from frequently touching up your edges frequently enough to never notice the "chipping" i'm referring to above (you know them already). The two methods:
1) add a couple of degrees manually (no guide) to the primary bevel and sharpen the edge of the chisel
2) reference the hollow against a stone and do the same thing you'd do with a flat bevel - sharpen only a single bevel, and refresh the hollow as needed.
I assure you that in general use for joinery and other such things, your edges are no sharper than mine, no more quickly arrived to, and nor are mine any less "intimate".
I don't, however, care how hard a chisel is with the method that I use, nor what steel. And I don't have to have great stones to get a very good edge regardless of the hardness of the steel. To me, that's a lovely benefit.
But chisels aren't the only thing to be sharpened, planes are included, too. You will see significant wear on the iron if you are dimensioning your wood by hand and doing so in quantity, and the hollow does the same 1, 2 above, except the edge of a good plane iron will need touch up because of the level of wear, and not because of impact.
Messages In This Thread
Sharpening jig/grinding question
Re: Sharpening jig/grinding question
Re: the scots
Sharpening jig/grinding answer
Re: Sharpening jig/grinding answer
Re: Efficiency
Efficiency rarely a consideration on this Forum
Very well said. *NM*
Re: A grinder and two stones..
Razor hone questions
Sent you an email, Bill *NM*
Two most useful sharpening tools you can buy
Re: Two most useful sharpening tools you can buy
Amen to the hand lens *NM*
Good points, well stated. Diplomatic, even. *NM*
recommend that lens again.......
Funny you should compare it with your B&L *LINK*
You bet, Bill. Glad you like yours. *LINK*
Re: You bet, Bill. Glad you like yours.
at least sharp enough
Re: You could be plenty sharp to finish plane...
Re: Efficiency
Re: Efficiency
"Riding" hollow bevels on flat sharpening media
Whatever, but it's not inefficient. *NM*
Re: Tradtional Archery
Re: Good analogy! *NM*
Which came first...
Re: Which came first...
Full bevel
Re: Full bevel
My Method
TAANSTAFL
ADMIN! A reminder about civility
Re: A reminder about civility
didn't really answer my question
Re: didn't really answer my question
Flat bevel
Re: Flat bevel
Re: Flat bevel
Re: Flat bevel
chisel wear
Re: Flat bevel
Re: Flat bevel
We have been discussing this topic for years
Re: We have been discussing this topic for years
Sorry, I don't run your tests on command. Bill? *NM*
Re: Sorry, I don't run your tests on command. Bill
Smarm?! Hey, Bill, is this what you had in mind? *NM*
LV's plane blades, as shipped are sharp. *NM*
Yes, that's pretty much it
