Re: didn't really answer my question
David Weaver
It's more likely that you need to reread my statement and rethink it. If the break doesn't make it to the hollow, then it isn't due to the hollow.
Messages In This Thread
Sharpening jig/grinding question
Re: Sharpening jig/grinding question
Re: the scots
Sharpening jig/grinding answer
Re: Sharpening jig/grinding answer
Re: Efficiency
Efficiency rarely a consideration on this Forum
Very well said. *NM*
Re: A grinder and two stones..
Razor hone questions
Sent you an email, Bill *NM*
Two most useful sharpening tools you can buy
Re: Two most useful sharpening tools you can buy
Amen to the hand lens *NM*
Good points, well stated. Diplomatic, even. *NM*
recommend that lens again.......
Funny you should compare it with your B&L *LINK*
You bet, Bill. Glad you like yours. *LINK*
Re: You bet, Bill. Glad you like yours.
at least sharp enough
Re: You could be plenty sharp to finish plane...
Re: Efficiency
Re: Efficiency
"Riding" hollow bevels on flat sharpening media
Whatever, but it's not inefficient. *NM*
Re: Tradtional Archery
Re: Good analogy! *NM*
Which came first...
Re: Which came first...
Full bevel
Re: Full bevel
My Method
TAANSTAFL
ADMIN! A reminder about civility
Re: A reminder about civility
Flat bevel
Re: Flat bevel
Re: Flat bevel
Re: Flat bevel
chisel wear
Re: Flat bevel
Re: Flat bevel
We have been discussing this topic for years
Re: We have been discussing this topic for years
Sorry, I don't run your tests on command. Bill? *NM*
Re: Sorry, I don't run your tests on command. Bill
Smarm?! Hey, Bill, is this what you had in mind? *NM*
LV's plane blades, as shipped are sharp. *NM*
Yes, that's pretty much it
