Re: didn't really answer my question
david weaver
I agree with larry on all of these. I can't see how using a 6" grinder is a stone age issue. I can't think that there are any electric tools that produce a good edge faster than a grinder and two stones. Three out of four full sharpenings take about 30 seconds for me. The fourth takes an additional 30 seconds to refresh a hollow.
In five years, I've never broken a hollow ground edge. at least not to the hollow. And if it's not broken up to the hollow, it has nothing to do with being hollow ground.
A power system is much more threat to an edge than a dry grinder. If I ever grind to the edge, I do just get to it, but usually grind until just 1/2 hair short.
I used more edge when I was sharpening by hand and using several bevels, because it was always tempting to run the second bevel in a jig back hard to make sure the edge is clean.
It's my opinion that most who do all of their work with hand tools will eventually move toward a dry grinder or a high speed belt sander, or they'll possibly lean toward only the oldest plain steel tools and work entirely by hand with a very coarse stone and perhaps two others (warren?).
I never became obsessed with sharpening faster but just as sharp and clean until I dumped using my TS, planer and jointer. Wear on my plane irons and chisels is still creeping along at a slow pace, probably slower now that I don't use a guide and really hammer away at a second bevel with the 1000 stone.
Messages In This Thread
Sharpening jig/grinding question
Re: Sharpening jig/grinding question
Re: the scots
Sharpening jig/grinding answer
Re: Sharpening jig/grinding answer
Re: Efficiency
Efficiency rarely a consideration on this Forum
Very well said. *NM*
Re: A grinder and two stones..
Razor hone questions
Sent you an email, Bill *NM*
Two most useful sharpening tools you can buy
Re: Two most useful sharpening tools you can buy
Amen to the hand lens *NM*
Good points, well stated. Diplomatic, even. *NM*
recommend that lens again.......
Funny you should compare it with your B&L *LINK*
You bet, Bill. Glad you like yours. *LINK*
Re: You bet, Bill. Glad you like yours.
at least sharp enough
Re: You could be plenty sharp to finish plane...
Re: Efficiency
Re: Efficiency
"Riding" hollow bevels on flat sharpening media
Whatever, but it's not inefficient. *NM*
Re: Tradtional Archery
Re: Good analogy! *NM*
Which came first...
Re: Which came first...
Full bevel
Re: Full bevel
My Method
TAANSTAFL
ADMIN! A reminder about civility
Re: A reminder about civility
Flat bevel
Re: Flat bevel
Re: Flat bevel
Re: Flat bevel
chisel wear
Re: Flat bevel
Re: Flat bevel
We have been discussing this topic for years
Re: We have been discussing this topic for years
Sorry, I don't run your tests on command. Bill? *NM*
Re: Sorry, I don't run your tests on command. Bill
Smarm?! Hey, Bill, is this what you had in mind? *NM*
LV's plane blades, as shipped are sharp. *NM*
Yes, that's pretty much it
